Tensile Modulus - or Young's Modulus alt. Modulus of Elasticity - is a measure of stiffness of an elastic material. It is used to describe the elastic properties of objects like wires, rods or columns when they are stretched or compressed.
Tensile Modulus is defined as the
"ratio of stress (force per unit area) along an axis to strain (ratio of deformation over initial length) along that axis"
It can be used to predict the elongation or compression of an object as long as the stress is less than the yield strength of the material. More about the definitions below the table.
Young's Modulus, Tensile Strength and Yield Strength Values common Materials
MaterialTensile Modulus
(Young's Modulus, Modulus of Elasticity)
- E -
(GPa)
Ultimate Tensile Strength
- σu -
(MPa)
Yield Strength
- σy -
(MPa)
ABS plastics 1.4 - 3.1 40
A53 Seamless and Welded Standard Steel Pipe - Grade A 331 207
A53 Seamless and Welded Standard Steel Pipe - Grade B 414 241
A106 Seamless Carbon Steel Pipe - Grade A 330 205
A106 Seamless Carbon Steel Pipe - Grade B 415 240
A106 Seamless Carbon Steel Pipe - Grade C 485 275
A252 Piling Steel Pipe - Grade 1 345 207
A252 Piling Steel Pipe - Grade 2 414 241
A252 Piling Steel Pipe - Grade 3 455 310
A501 Hot Formed Carbon Steel Structural Tubing - Grade A 400 248
A501 Hot Formed Carbon Steel Structural Tubing - Grade B 483 345
A523 Cable Circuit Steel Piping - Grade A 331 207
A523 Cable Circuit Steel Piping - Grade B 414 241
A618 Hot-Formed High-Strength Low-Alloy Structural Tubing - Grade Ia & Ib 483 345
A618 Hot-Formed High-Strength Low-Alloy Structural Tubing - Grade II 414 345
A618 Hot-Formed High-Strength Low-Alloy Structural Tubing - Grade III 448 345
API 5L Line Pipe 310 - 1145 175 - 1048
Acetals 2.8 65
Acrylic 3.2 70
Aluminum Bronze 120
Aluminum 69 110 95
Aluminum Alloys 70
Antimony 78
Aramid 70 - 112
Beryllium (Be) 287
Beryllium Copper 124
Bismuth 32
Bone, compact 18 170
(compression)
Bone, spongy 76
Boron 3100
Brass 102 - 125 250
Brass, Naval 100
Bronze 96 - 120
CAB 0.8
Cadmium 32
Carbon Fiber Reinforced Plastic 150
Carbon nanotube, single-walled 1000
Cast Iron 4.5% C, ASTM A-48 170
Cellulose,  cotton, wood pulp and regenerated 80 - 240
Cellulose acetate, molded 12 - 58
Cellulose acetate, sheet 30 - 52
Cellulose nitrate, celluloid 50
Chlorinated polyether 1.1 39
Chlorinated PVC (CPVC) 2.9
Chromium 248
Cobalt 207
Concrete 17
Concrete, High Strength (compression) 30 40
(compression)
Copper 117 220 70
Diamond (C) 1220
Douglas fir Wood 13 50
(compression)
Epoxy resins 3-2 26 - 85
Fiberboard, Medium Density 4
Flax fiber 58
Glass 50 - 90 50
(compression)
Glass reinforced polyester matrix 17
Gold 74
Granite 52
Graphene 1000
Grey Cast Iron 130
Hemp fiber 35
Inconel 214
Iridium 517
Iron 210
Lead 13.8
Magnesium metal (Mg) 45
Manganese 159
Marble 15
MDF - Medium-density fiberboard 4
Mercury
Molybdenum (Mo) 329
Monel Metal 179
Nickel 170
Nickel Silver 128
Nickel Steel 200
Niobium (Columbium) 103
Nylon-6 2 - 4 45 - 90 45
Nylon-66 60 - 80
Oak Wood (along grain) 11
Osmium (Os) 550
Phenolic cast resins 33 - 59
Phenol-formaldehyde molding compounds 45 - 52
Phosphor Bronze 116
Pine Wood (along grain) 9 40
Platinum 147
Plutonium 97
Polyacrylonitrile, fibers 200
Polybenzoxazole 3.5
Polycarbonates 2.6 52 - 62
Polyethylene HDPE (high density) 0.8 15
Polyethylene Terephthalate, PET 2 - 2.7 55
Polyamide 2.5 85
Polyisoprene, hard rubber 39
Polymethylmethacrylate (PMMA) 2.4 - 3.4
Polyimide aromatics 3.1 68
Polypropylene, PP 1.5 - 2 28 - 36
Polystyrene, PS 3 - 3.5 30 - 100
Polyethylene, LDPE (low density) 0.11 - 0.45
Polytetrafluoroethylene (PTFE) 0.4
Polyurethane cast liquid 10 - 20
Polyurethane elastomer 29  - 55
Polyvinylchloride (PVC) 2.4 - 4.1
Potassium
Rhodium 290
Rubber, small strain 0.01 - 0.1
Sapphire 435
Selenium 58
Silicon 130 - 185
Silicon Carbide 450 3440
Silver 72
Sodium
Steel, High Strength Alloy ASTM A-514 760 690
Steel, stainless AISI 302 180 860 502
Steel, Structural ASTM-A36 200 400 250
Tantalum 186
Thorium 59
Tin 47
Titanium
Titanium Alloy 105 - 120 900 730
Tooth enamel 83
Tungsten (W) 400 - 410
Tungsten Carbide (WC) 450 - 650
Uranium 170
Vanadium 131
Wrought Iron 190 - 210
Wood
Zinc 83
  • 1 Pa (N/m2) = 1×10-6 N/mm2 = 1.4504×10-4 psi
  •  1 MPa = 106 Pa (N/m2) = 0.145×103 psi (lbf/in2) = 0.145 ksi
  • 1 GPa = 109 N/m2 = 105 N/cm2  = 103 N/mm2 = 0.145×106 psi (lbf/in2)
  • 1 Mpsi = 106 psi = 103 ksi
  • 1 psi (lb/in2) = 0.001 ksi = 144 psf (lbf/ft2) = 6,894.8 Pa (N/m2) = 6.895×10-3 N/mm2
Tension Unit Converter Chart
Download and print Tension Unit Converter Chart
Example - Convert between Tension Units
10000 psi can be converted to 0.069 GPa and 10 ksi as indicated in the chart below:
Tension unit converter chart example
Note! - this online pressure converter can also be used to convert between Tensile Modulus units.
Strain - ε
Strain is the "deformation of a solid due to stress" - change in dimension divided by the original value of the dimension - and can be expressed as
ε = dL / L                                          (1)
ε = strain (m/m, in/in)
dL = elongation or compression (offset) of object (m, in)
L = length of object (m, in)
Stress - σ
Stress is force per unit area and can be expressed as
σ = F / A                                           (2)
σ = stress (N/m2, lb/in2, psi)
F = applied force (N, lb)
A = stress area of object (m2, in2)
  • tensile stress - stress that tends to stretch or lengthen the material - acts normal to the stressed area
  • compressible stress - stress that tends to compress or shorten the material - acts normal to the stressed area
  • shearing stress - stress that tends to shear the material - acts in plane to the stressed area at right-angles to compressible or tensile stress
Young's Modulus - Tensile Modulus, Modulus of Elasticity - E
Young's modulus can be expressed as
E = stress / strain
   =  σ / ε
   = (F / A) / (dL / L)                                    (3)
E = Young's Modulus of Elasticity (Pa, N/m2, lb/in2, psi)
  • named after the 18th-century English physician and physicist Thomas Young
Elasticity
Elasticity is a property of an object or material indicating how it will restore it to its original shape after distortion.
A spring is an example of an elastic object - when stretched, it exerts a restoring force which tends to bring it back to its original length. This restoring force is in general proportional to the stretch described by Hooke's Law.
Hooke's Law
It takes about twice as much force to stretch a spring twice as far. That linear dependence of displacement upon the stretching force is called Hooke's law and can be expressed as
Fs = -k dL                                          (4)
Fs = force in the spring (N)
k = spring constant (N/m)
dL = elongation of the spring (m)
Note that Hooke's Law can also be applied to materials undergoing three dimensional stress (triaxial loading).
Yield strength - σy
Yield strength is defined in engineering as the amount of stress (Yield point) that a material can undergo before moving from elastic deformation into plastic deformation.
  • Yielding - a material deforms permanently
The Yield Point is in mild- or medium-carbon steel the stress at which a marked increase in deformation occurs without increase in load. In other steels and in nonferrous metals this phenomenon is not observed.
Ultimate Tensile Strength - σu
The Ultimate Tensile Strength - UTS - of a material is the limit stress at which the material actually breaks, with a sudden release of the stored elastic energy.
